color correction problem when moving project between machines
Rob Alexander
on Jan 22, 2016 at 7:13:22 pm
I have a problem whereby when I move my project from my studio to my clients' the color correction changes (it appears to be the basic input LUT mostly). The media and project are all on a portable drive which I just plug in to either computer.
What's going on here? Please help!!
Thanks.
PPro CC15, Mac
Tero Ahlfors
Re: color correction problem when moving project between machines
on Jan 22, 2016 at 10:06:56 pm
If the media/project/effects are the same then the only thing would be that the monitors aren't calibrated.
Rob Alexander
on Jan 22, 2016 at 11:37:27 pm
Thanks Tero but the LUT in the drop down menu had actually changed - in this case from an ARRI Amira setting to an Arri Alexa, and the look was wildly different. It has happened every time I've moved suites.
The monitors in both locations are well matched.
Chris Borjis
on Jan 23, 2016 at 12:52:24 am
Are you certain both machines are running the exact same
version of premiere? (and both pc or both mac, not one pc one mac)
That shouldn't be happening.
Maybe you discovered a new bug to report to Adobe
