PP CS 6 Black screen playback
Ron Pestes
on Jan 21, 2016 at 7:54:35 pm
I just reinstalled CS 6 in my new computer but when I try to open an old project it says it needs to convert to the newer version even though it is the same program from before. If I say ok it only shows a black screen during playback although I can hear the audio just fine. This happens in the browser and both preview and program monitors. All updates for CS 6 are installed. What should I do?
ronpesteshdvideo.com
JVC GY-HM600
Dell M6600
Adobe CS6 Production Premium
MacBook Pro
Apple Certified Master Pro FCS 2
Ron Pestes
Re: PP CS 6 Black screen playback
on Jan 21, 2016 at 9:13:20 pm
Using Windows 10
JVC GY-HM600
Dell M6600
MacBook Pro
Jeff Pulera
on Jan 21, 2016 at 9:18:19 pm
Perhaps the previous Premiere installation was not up to date, and therefore the prior project does need updating to the "new" software?
In any case, let Premiere update the project - it doesn't hurt the original, just makes a copy. Then do SAVE AS to save the new version.
Jeff Pulera
Safe Harbor Computers
Ron Pestes
on Jan 21, 2016 at 10:04:18 pm
Ok, but that does not fix the black screen during playback. The clips play fine with Quicktime or VLC
JVC GY-HM600
Dell M6600
MacBook Pro
Jeff Pulera
on Jan 21, 2016 at 11:04:13 pm
If you create a NEW project, drop in a clip, play, same issue?
Want to determine if something is wrong with old project, or if there's some overall issue with using CS6 on the new Windows 10 machine in general.
Jeff Pulera
Ron Pestes
on Jan 21, 2016 at 11:07:31 pm
New projects are the same. Using a Acer Predator 15 laptop.
JVC GY-HM600
Dell M6600
MacBook Pro
Ron Pestes
on Jan 22, 2016 at 12:41:48 am
Problem solved. It was an out of date video driver. Thanks for the advice.
JVC GY-HM600
Dell M6600
MacBook Pro
