Frame Blending "issue" when changing speed in Premiere Pro
Catalin Buda
on Jan 21, 2016 at 5:48:04 pm
Hi guys
I don't understand the way frame-blending is done in Premiere when you slow down a clip.
For example, if I import a 29,97fps clip into a 29,97fps sequence and then I change the speed of that clip to 75% without enabling the Frame-Blending (and using the default Frame Sampling method for the Time Interpolation), the result is that every 3rd frame (of the original clip) is doubled, so I get: 1 2 3 3 4 5 6 6 7 8 9 9 and so on. Which is normal.
The problem is when I set Frame Blending for the Time Interpolation method. I expected to get frame blending only when a frame was doubled, like this: 1 2 3 (3+4) 4 5 6 (6+7) 7 8 9 (9+10) and so on, but instead, Premiere does it almost the opposite way and applies the frame blending to all the frames except the 3rds, so what I get is something like this: (1+2) (2+3) 3 (3+4) (4+5) (5+6) 6 (6+7) (7+8) (8+9) 9 (9+10).
Does anyone know why is this? Is there a way to change this behavior and make Premiere blend only the frames that are doubled?
Cheers
Catalin Buda
Re: Frame Blending "issue" when changing speed in Premiere Pro
on Jan 26, 2016 at 1:10:24 am
Anyone?
I was thinking a lot of people encountered this issue when slowing down videos.
Chris Wright
on Feb 1, 2016 at 4:21:31 am
premiere creates new frames by nearest frame match. if you want another way, like time interpolation with optical flow, use that instead. if you just want another way to custmozie frame blending, you'll have to get avisynth.
Catalin Buda
on Feb 4, 2016 at 3:03:10 pm
Thanks, Chris!
I never used Avisynth, but I might give it a try.
