CC Premiere - Full mp4 export process to produce only a 24kb file.
Stefan Day
on Jan 18, 2016 at 6:48:12 pm
Not sure what's going on here.
Via file > export media I am setting an HD sequence to encode to the Vimeo HD 29.97 preset for H.264.
The sequence is approx. 2hrs long. The software runs through the full encode process.. several hours then turns out an .mp4 that is only 24kbs. I have repeated this process twice with the same outcome.
I have done this SAME process many times before without a hitch. Nothing has changed, that I am aware of, with my setup.
Any clues on what might be happening?
Jeff Pulera
Re: CC Premiere - Full mp4 export process to produce only a 24kb file.
on Jan 18, 2016 at 10:22:35 pm
Clean out the Premiere cache.
Make sure Destination drive has adequate space available.
Make sure export filename path is not extra long.
Make sure filename does not contain "special characters" reserved for system use, like punctuation and such. Keep it simple.
I would make appropriate changes if applicable and try a short export segment before committing to the long render of full movie again.
Jeff Pulera
Safe Harbor Computers
Tero Ahlfors
on Jan 19, 2016 at 7:32:11 am
Also make sure you have selected the correct source range.
