Premiere Pro Clip Slipping? Basic tips required!
James Smith
on Jan 17, 2016 at 11:22:50 pm
Amateur question I know!
I'm used to final cut pro, it made space automatically when dragging clips to the timeline. But when I drag and drop media to the timeline on Premiere it cuts into chunks of clips either side. Any advice for how not have this problem?
Tero Ahlfors
Re: Premiere Pro Clip Slipping? Basic tips required!
on Jan 18, 2016 at 5:30:50 am
https://helpx.adobe.com/premiere-pro/using/adding-clips-sequences.html
Chris Evans
on Jan 18, 2016 at 3:26:59 pm
Tero has a great resource that you should definitely read, but I'll give you the quick version.
Hold ctrl while dragging
or
press the insert button at the bottom of the source window
or
press the insert keyboard shortcut (default ',')
Pressing the insert button or keyboard shortcut will insert the clip at your playhead in the timeline, moving/splitting any clips in tracks you have the toggle sync turned on for.
James Smith
on Jan 18, 2016 at 5:48:31 pm
Thanks very much! Do you know where I could find the Tero resource?
