Moving keyframe link an accordion when you are changing clip length
Scott Clements
on Jan 12, 2016 at 12:58:30 pm
Let's say you have a complex move on you clip, with several keyframes laid out. But then, you wish to change the length of your clip with a ripple trim... is there any way to make those keyframes scale across time? To make them accordion in and out as you trim your clip? I know you can do this in After Effects. Thanks!
Film Editor, London UK
http://www.scottclementseditor.com
Alex Udell
Re: Moving keyframe link an accordion when you are changing clip length
on Jan 12, 2016 at 2:41:42 pm
The closest I think you can get is to save the effect as a preset and choose the "scale" option....
then reset and reapply affter the trim...
and the effect will be applied proportionally to the new length....
if I'm wrong....I'd be happy to know it. :)
hth,
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Scott Clements
on Jan 13, 2016 at 8:40:11 am
Thanks for trying to confirm this, Alex! And for the workaround!
