Clip marker - shortcut for each color of marker
veronique barbe
on Jan 11, 2016 at 11:50:55 pm
Did anyone find a way to assign a shortcut to each color of clip marker in Premiere CC 9.1 ? (like in Avid or Final cut)
By now, I have to change the color of the marker in the marker window each time I add a new one... a big waste of time.
NB : I know chapter markers have a different color but they are sequence markers, and I only want to use CLIP markers.
NB 2 : clip colors - I already use different clip colors so it wouldn't be a solution to replace the markers.
Hope there is a solution,
Thanks !!
Véronique Barbe
Monteure | Editor
https://vimeo.com/veroniquebarbe
John Baumchen
Re: Clip marker - shortcut for each color of marker
on Jan 12, 2016 at 1:57:10 am
I share your pain. It doesn't seem like it would be a hard thing to allow one to select a default color for markers, but then, I do remember when they were only one color.
veronique barbe
on Jan 12, 2016 at 2:08:26 am
Thanks John !
I will fill a request to adobe.
http://www.adobe.com/products/wishform.html
Having shortcuts for each color of clip marker should be a basic thing to have.
Cheers,
Véronique Barbe
Monteure | Editor
Clarke Leland
on Mar 1, 2016 at 8:27:33 pm
It may not be possible to have a single key to set say a "red" marker. But you can set a key to change the color after its been placed (pressing "M")
I just found this out, you can go to the keyboard shortcuts and assign a quick key for "marker color #1", "marker color #1", etc. These correspond to the arrangement, left to right, of markers in the marker window. #1 is Green, #2 is Red, so on and so forth. Not exactly the trick, but hopefully it will speed up the process.
