Trim audio and video with T shortcut even if the audio isn't cut at the same place than the video ?
Marc De Coster
on Jan 11, 2016 at 12:10:00 pm
Hi.
I'll have to work on a TV show at the end of the month, I want to use Premiere, and I'm practicing my shortcuts :-)
Trimming will be a huge part of the editing of course so I want it to be fast.
Here is the thing:
Let's pretend that audio isn't cut at the same place than the video, like this
When I hit T to open the trim window Premiere doesn't select both audio and video. It means that I have to click on each cut to select them. It's really boring.
Do you know a way to select that edit (video and audio) in the same time?
Thank you all.
