Suggestions on picking the right settings and codecs
Spyros Psarras
on Jan 5, 2016 at 12:56:15 pm
Hai there guys. I have been looking this forum for around a year and its time I have to ask you some questions on what I am supposed to choose.
First things first, I have to tell you what I am currently doing and I'm not satisfied with the result. The videos are posted afterwards to YouTube.
I am capturing my screen while I play League of Legends with OBS using the VCE from ati radeon. My specs aren't that good, so I have to use this method to achieve 60FPS for my videos.
MediaInfo results:
General
Complete name : D:\Video\Capture\2016-01-04-1500-32.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 330 MiB
Duration : 55s 71ms
Overall bit rate : 50.2 Mbps
Encoded date : UTC 2016-01-04 13:01:29
Tagged date : UTC 2016-01-04 13:01:29
Writing application : Open Broadcaster Software v0.657b
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=60
Muxing mode : Container profile=High@3.1
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 55s 66ms
Source duration : 55s 50ms
Bit rate : 50.0 Mbps
Width : 1 920 pixels
Height : 1 200 pixels
Display aspect ratio : 16:10
Frame rate mode : Variable
Frame rate : 60.000 fps
Minimum frame rate : 58.824 fps
Maximum frame rate : 62.500 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.362
Stream size : 328 MiB (100%)
Source stream size : 328 MiB (100%)
Color range : Limited
mdhd_Duration : 55066
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 55s 71ms
Source duration : 55s 19ms
Bit rate mode : Constant
Nominal bit rate : 320 Kbps
Channel(s) : channel0
Channel(s)_Original : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Source stream size : 1.39 MiB (0%)
Language : English
Before, I was using DXtory and https://github.com/jackun/TestAMFVFW codec to capture using my GPU for rendering on the fly, but found a better result using OBS with VCE. Also, before, since the result wasn't stable 60FPS I was using MEGUI and SVP's dlls to smoothen the video and make the video constant 60FPS (http://www.spirton.com/convert-videos-to-60fps/)
Well, back to what I'm currently doing. After capturing the video using OBS, the mp4 is for a minute around 900MB or so, and I'm importing it to premiere, doing my staff and then the project goes to media encoder. There I am using H264 with 1080p resolution, 5.1 lvl, and I am experimenting with bitratio. VBR 2 passes. The bitratio is most of the times min 8 max 12, but the result is not that good. When I am upscaling the video to 1600p with 50 and 75Mbps bitrate then video still doesn't look THAT good as the raw and the file for 10min becomes 3.5GB which is impossible to upload with my internet connection at the moment. What should I do? Oh forgot to mention also, that for 10min video I am waiting for around 2.5 hours to finish the rendering with yellow bar on premiere.
Thanks in advance for the help and for reading.
