Audio Dynamic link
Stephane Pelé
Audio Dynamic link
on Jan 4, 2016 at 10:26:26 am
Hello !
Since the two last update of Adobe CC i meet this pb :
I have an audio sequence in premiere wich i impot in After Effects via dynamic link, when i play the audio dynamic link in AE there are some repetition of words (i notice it happens where i have some cut in my audio sequence in premiere) i have contacted adobe support the only answer is to reinstall the suite.
Before theses updates everything worked fine..
Some of you have this problem ?
Thanks for your help!
Stéphane, Paris.
Windows 10/ Creative suite 2015.1/ 32Go Ram/ Graphic card Nvidia GTX 980 / Intel core i7 @3.50GHz
Chris Evans
Re: Audio Dynamic link
on Jan 4, 2016 at 5:49:34 pm
I don't have any ideas, but things I'd check. Do your comp and sequence have the same framerate? Are the files being interpreted the same way(Right click>modify>audio channels or interpret footage)? Do you have any effects on your audio that would change the length?
Why are you dynamic linking an audio sequence from Premiere to AE?
Stephane Pelé
on Jan 4, 2016 at 6:13:45 pm
Hello Chris,
My comp in AE and my sequence in Premiere have the same framerate (25 f/s).
Files are interpreted the same way.
Dynamic effect only in Premiere. (tried without, still the same).
I am using dynamic link with my audio sequence because my project in AE is a full animation with character and lips-sync, when i need to adjust my audio on my animation i don't need to make an .wav export for each modification or cut, what i found is very usefull with this method, which was working very well before i updated.
Chris Evans
on Jan 4, 2016 at 11:24:51 pm
Well, report it as a bug to Adobe. I don't know what to tell you.
When you do a RAM preview, make sure you wait for the whole thing to render before watching it. They updated it so it plays what is rendered until it gets to the part that is currently rendering. I doubt that's your problem, but it was just a last thought. Hopefully Adobe will fix it. I'd ask their Support too.
Stephane Pelé
on Jan 5, 2016 at 8:53:21 am
If anyone met the same problem, let me know if you find a solution.
Thanks.
