Creative Lut Problems in PP and AME
David Powell
on Dec 30, 2015 at 6:06:25 am
I'm using Deluts and the first problem is PP completely freezes up in Open CL mode when I switch back to software mode it acts properly but now I'm dealing with the limited processing power of software mode vs open CL when color correcting.
The second problem is AME doesn't recognize the creative luts so I'm unable to background export. The picture comes out missing the grade. Everything works properly when I export using PP but not when I use AME. This puts a big wrench in my workflow as most exports take hours.
I have the latest update on an imac 5k.
Alex Udell
Re: Creative Lut Problems in PP and AME
on Dec 30, 2015 at 3:15:54 pm
When you say....
thru AME...
What procedure are you using?
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
David Powell
on Dec 30, 2015 at 10:25:45 pm
I use "export media" from PP and then "queue" to send it to AME for export.
Alex Udell
on Dec 31, 2015 at 1:27:00 pm
hmmmmmm.....
weird...beacuse that technically uses a "headless" no GUI version PPro to do the rendering....
when it's in AME....
if you open the encoding setup....
is AME using GPU?
toggle that and see if that helps...
Alex Udell
