32-bit colour processing in Premiere
Oscar Gotti
on Dec 30, 2015 at 1:41:52 am
If I grade my video with Premiere using it's 32-bit colour processing...
Is there actually any point in doing this if you're exporting to an 8-bit codec such as H.264?
Tero Ahlfors
Re: 32-bit colour processing in Premiere
on Dec 30, 2015 at 7:51:48 am
The benefit of higher bit colour processing is that you're not stuck with 8-bit values down the line. If you crush the blacks in a previous correction you should be able to bring those back in a later correction.
Oscar Gotti
on Dec 30, 2015 at 1:11:58 pm
But will it also mean giving my footage for "steps" between the values? Giving my grade a smoother look with smoother gradients?
And would this follow through to my export even if I am exporting to an 8bit codec?
Tero Ahlfors
on Dec 30, 2015 at 1:46:13 pm
It does not make your footage any better or worse. It just has bigger values do deal with the mathematics that's going on with the image processing.
