Couple of Quick Questions
albert trevino
on Dec 26, 2015 at 5:44:52 pm
Got a new computer set up to finish a project and just purchased a good secondary monitor.
It will be here in a few days and have one basic question about setting it up.
We got the ASUS PA328Q from Amazon.
http://www.amazon.com/gp/product/B00YWD9ZZM?psc=1&redirect=true&ref_=oh_aui...
The project is a mix of going between AE and Premiere Pro. The entire project is in 1080p. This monitor supports 4K resolution. If I set it up at 4K as a secondary display, would it effect how Premiere and AE display it as a video preview? Would it be "up rez'd" and pixelated? Would it display better than if we had it configured at 1080p resolution on the monitor?
Vince Becquiot
Re: Couple of Quick Questions
on Dec 27, 2015 at 7:43:23 pm
Unless you are editing 4K, use it for your desktop.
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
albert trevino
on Dec 28, 2015 at 4:14:16 am
Ok. That doesn't entirely answer my question.
It is already configured to be a secondary monitor. Curious about setting up the resolution for this monitor to be 1080p or 4k as a secondary monitor and if it will effect the display as a preview monitor for editing.
Vince Becquiot
on Dec 28, 2015 at 4:28:40 am
You want to see your video without any distortion, that means seeing your preview pixel to pixel. Ideally that would actually be a broadcast, monitor as regular TV screens are nearly impossible to calibrate.
That also applies to After Effects where your preview at 100% will only fit half the screen), upscaling in AE will just look awful.
So, I would definitely use the 1080 monitor as preview. That also gets you additional real estate on the desktop which is really useful.
Vince Becquiot
albert trevino
on Dec 30, 2015 at 4:35:34 am
Ok. Thanks.
One last question. Not sure if it really matters on this setting.
The AE project is set to 16bpc. The monitor is set to display at 8bpc. There is no 16bpc setting for it. It goest from 8,10 and 12. Does that matter when displaying a 16bpc AE project on a display setting at 8bpc?
