Premiere pro hardware upgrade
Dominik Sulser
on Dec 24, 2015 at 11:48:56 pm
dear forum
i want to upgrade my hardware my goal is to make to waiting times shorter for rendering, stabilizing etc.
i actually don't know which part should be upgraded and which parts i can still let on the Board.
my setup is:
Board: Gigabyte 990FXA-UD3
CPU: AMD FX-8320 8-core 4.23 GHz
Ram: 12GB
GPU: nvidia geforce gtx 970 4GB
SSD and HDD does it matter?
need more informatin? please ask!
thank you for support!
Dominik
Ivan Myles
Re: Premiere pro hardware upgrade
on Dec 26, 2015 at 2:24:37 am
Hardware constraints will vary at different stages of the process. Have you tried using any system tools to monitor performance during the render/encode process? In general, SSD(s) would be a high priority. RAID with high speed I/O might be required depending on your usage scenario. Additional RAM is a low cost upgrade. Also consider things like a UPS and disk backup system which won't necessarily boost performance, but might save time if something goes wrong.
