Laptop like audio
Spencer Tycksen
Laptop like audio
on Dec 22, 2015 at 6:48:41 pm
I need to put an audio filter on a track to make it sound like it is coming from a laptop. Any tips on how to create that effect?
David Roth Weiss
Re: Laptop like audio
on Dec 22, 2015 at 9:07:10 pm
The easiest solution: record the audio playback from your laptop speakers on to your smart phone, then bring that into Premiere.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Paul Neumann
on Dec 22, 2015 at 11:23:04 pm
In Audition try Filter and EQ/FFT Filter/Telephone-Voicemail.
Ivan Myles
on Dec 23, 2015 at 1:04:57 pm
[Paul Neumann] "In Audition try Filter and EQ/FFT Filter/Telephone-Voicemail."
A similar outcome can be achieved in Premiere Pro with a lowpass filter and adjusting the cut-off frequency.
Alternatively, if you want a "tinny" sound use the Equalizer Effect to reduce low frequencies and increase high frequencies. Also, if the source audio is stereo consider balancing the output to emulate mono.
Spencer Tycksen
on Jan 4, 2016 at 5:24:46 pm
This worked perfectly. Thanks everyone for the help.
