Edit clip in Adobe Audition Grayed out
christina rule
on Dec 21, 2015 at 6:03:27 pm
Hi All. I am working on a project in premier and I need to take some of the background noise out of an audio track. I normally do this in Adobe Audition, however when I right click and try to do this and right click on the track the " Edit Clip in Adobe Audition" is grayed out. Not sure why this is. The files are from Cannon c300 and are mxf format. I use to have no issue with this before.
Primer Pro version: Latest CC 2015.1
Audition Version: CC 2015.1
http://www.christinarule.com
Tero Ahlfors
Re: Edit clip in Adobe Audition Grayed out
on Dec 21, 2015 at 6:34:33 pm
You need to select a clip with audio in the timeline.
christina rule
on Dec 21, 2015 at 6:39:25 pm
Hey Thanks for the response. This clip does have audio on the timeline.
christina rule
on Dec 22, 2015 at 7:24:39 pm
Any other ideas?
