side by side compare different effects
Dan Sakols
on Dec 20, 2015 at 2:33:20 am
Im playing around with different effects to adjust tone and contrast. Id like to find a way to see the result of different effects (i.e. a curves adjustment vs fast color corrector adjustment) on the same picture side by side. I can of course turn them each on and off, but can't see them next to each other. Is there a way?
thanks and happy holidays
dan
Jogen Liesendahl
Re: side by side compare different effects
on Dec 20, 2015 at 12:14:36 pm
Duplicate your file, drag one of them on V2, crop one file so you can see both clips in the viewer, paste different sfx on each.
...that´s how I would proceed...
Jo
Ivan Myles
on Dec 20, 2015 at 3:18:28 pm
[Jogen Liesendahl] "crop one file so you can see both clips in the viewer"
Or scale and position side be side.
I find it easier to make comparisons with the scopes by overlaying and toggling the upper track.
