Having Matte issues in Premiere
Dustin Straube
on Dec 17, 2015 at 7:35:27 pm
Hi all,
I'm trying to create the effect of a floating head (it's silly), and for some reason all of the mattes I apply are causing effects that I can't explain. It puts the layer I'm matting and repositions it into the lower right corner and it's impossible for me to do anything with it at that point. The position only changes when the matte is applied, otherwise everything is where it should be. But I need to matte out the body.
Here is an image that shows what's happening...
Dustin Emerson Straube
dustin.straube@gmail.com
Ann Bens
Re: Having Matte issues in Premiere
on Dec 17, 2015 at 10:08:50 pm
Make sure you have the latest version installed otherwise
Turn off MPE hardware.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Dustin Straube
on Dec 17, 2015 at 10:19:18 pm
THANKS!
Turned off MPE hardware and that worked like a charm. Any explanation as to why that causes that?
Tero Ahlfors
on Dec 18, 2015 at 7:58:04 am
[Dustin Straube] "Turned off MPE hardware and that worked like a charm. Any explanation as to why that causes that?"
Do you have a supported GPU?
