Problems using PHYX Keyer
Rui Manuel
on Dec 17, 2015 at 4:38:03 pm
Hello there.
I am eager to buy the PHYX Keyer Plugin Suite, but even after seeing the tutorial videos I can't get anything but very poor results.
I am sure I am doing something wrong, but can't see what it is. I am using the TRIAL version 5.2 now, but really need to buy it.
Here are some details:
1 - I am using Adobe Premiere Pro V 7.2.1
2 - Under Mac OSX Yosemite V 10.10
I attach some image that shows the best I could get until now.
What am I doing wrong? I already have tried all the possible configurations on the plugin, and these are the best I could get after trying all the possibilities.
Can somebody please help me on this?
Thank you so much in advance.
David Roth Weiss
Re: Problems using PHYX Keyer
on Dec 17, 2015 at 5:27:56 pm
What is your prior experience with keying?
Are you trying to do everything, including the hair with a single instance of the plugin?
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Rui Manuel
on Dec 17, 2015 at 5:35:57 pm
David, thank you for answering me.
I am not an expert in keying, I use a technique abour 1 year now. And yes I know I can use multiple instances of a plugin.
but in this case all the tutorials I saw it is just a single click and after that one or two minor adjustments do get it right.
in my case I cant get it right my no way, not even close!
thats why I am feeling lost here.
can you please help or suggest something? :/
Philippe Lessard
on Dec 18, 2015 at 3:19:55 pm
First, what kind of footage it is?
In case its H264 or any "compression codec" you will have trouble keying, especialy with the kind of footage you have(with a lot of hair around her head)even with professionnal tool, those shots are difficult.
The first thing to do is re-export your footage in 4444, prores 4444 or Animation codec will do it (not magic, but could help).In your screencap I see it in the plugin window, "reconstruction sampling"try to put it to 4444.
You shouldnt key in Premiere, do it in after effect instead, with keylight.
Before buying this pluging I will test the other included such as Ultrakey, and you should try the Keyer from Phyx not the Fast keyer...Always do your key in 100% resolution. Watch a online tutorial about keying.
Consider reshooting your talent with a tight ponytail, no hair messing around.
But you really should watch a online tutorial about keying...
Good luck
Rui Manuel
on Dec 20, 2015 at 9:43:28 pm
Thank you so much for your answer and kindness. :)
I will consider now all the points you referred to.
rui
