Premiere to After Effects Dynamic Link -Timecode problems
Erdem Oz
on Dec 16, 2015 at 8:42:49 pm
Hello,
I'm new to the forums, and I haven't been able to find an answer to my problem.
When I export a clip in Premier to After Effects by 'Replace with After Effects Comp" command, the timecode of the clip resets, and AE assigns its own timecode starting from 0 in the timeline. I'm trying to put an effect at a particular frame in the clip, so it's very important to have synchronized timecode between Premiere and After Effects.
Is there way to sync the timecode, or what are the alternative workflows to overcome this problem? I also do not want to export the whole sequence to After Effects, because I then lose all my edit points.
