Anyway to use premiere with pro res 4444 XQ?
evan halleck
on Dec 15, 2015 at 7:57:03 pm
So I recently got the footage from a shoot and it seems that they shot a codec I have not used before which is pro res 4444XQ It will not import in to premiere and it says codec unsupported. I have been goggling and it doesn't look like there is a ton of information about the codec yet. Can anyone recommend what are my options so I can begin editing? Thank you
Shane Ross
Re: Anyway to use premiere with pro res 4444 XQ?
on Dec 15, 2015 at 11:10:20 pm
You'll need an Apple ProApp installed...Compressor, Motion or FCX. Compressor is the cheapest.
Shane
Little Frog Post
evan halleck
on Dec 15, 2015 at 11:13:48 pm
Hmm, So if I bought Compressor It would then be able to import in to premiere?
Shane Ross
on Dec 15, 2015 at 11:30:35 pm
Top two google hits, BTW, for ProRes XQ:
https://support.apple.com/en-us/HT202410
https://larryjordan.com/blog/what-is-prores-4444-xq/
The codecs come with any installed Apple ProRes...and those three are it. So yes, if you buy Compressor, you should get that codec. See if Compressor has a 30-day trial, though. Like FCX does.
Shane
Little Frog Post
