Decompose (for you AVID guys)
Rich Rubasch
on Dec 14, 2015 at 10:27:47 pm
One thing did just come up. We have 4 cameras and 5 locations. We are using camera raw footage. We pull in broll from all 4 cameras from all 5 locations and make a selects broll sequence.
Any easy way to decompose that into just the clips used in the sequence (ok if its the entire clip) then populate a drive with the resulting footage and project and then send that to an editor to use the selected broll?
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
http://www.tiltmedia.com
James Ashbolt
Re: Decompose (for you AVID guys)
on Dec 15, 2015 at 12:48:58 am
Sounds like using project manager will be what you are after.
you can export the entire source clips used in a sequence/s or, with handles.
- J
Rich Rubasch
on Dec 15, 2015 at 6:44:35 pm
Found it. And by the way if you are using camera raw footage in a project when it bundles it all up it includes file path and all associated metadata for each clip on the export. It is a sweet little utility!
Rich Rubasch
Tilt Media Inc.
