White levels above 100...
Oscar Gotti
on Dec 10, 2015 at 11:07:40 pm
Hi all,
Just out of curiosity...
I've always wanted to know why some broadcasters won't accept videos with white levels above 100?
If the area above 100 is just over-exposed white, then why is that a problem for them?
Also, applying a video limiter for white levels is just making the over-exposed white less bright...The detail information is still lost... So why is that okay?
Thanks, just one of those questions I've always wanted to know...
Oscar
Shane Ross
Re: White levels above 100...
on Dec 11, 2015 at 12:16:45 am
An old spec for older TVs. Do you remember watching TV and when it hit some local commercial, that was really over exposed, there would be an audible BUZZ that came from the TV? Well, that's the issue. Whites that are above 100IRE can cause an audible buzz in audio. I won't say this doesn't affect newer HDTVs, because I have a 4 year old one in my bedroom, and when I play a certain VHS tape on it, one for the kids that is VERY hot (recorded off air), I get an audible buzz. So it's still an issue.
That's why there are restrictions on the white levels.
Shane
Little Frog Post
Oscar Gotti
on Dec 11, 2015 at 11:43:41 am
Thanks Shane,
So in theory, if something hot was to go on-air today, would it be more likely to create buzz on an older TV, rather than a newer HDTV?
Nowadays, do most broadcasters have their own broadcast safe filter applied to all their content due to go on air?
Curious that your VHS video would give that buzz... Are you sure the buzz isn't embedded on the tape itself? also, not sure what you mean by 'recorded off-air'?
Sorry about all the questions,
Mayto
Tero Ahlfors
on Dec 11, 2015 at 11:48:54 am
[Oscar Gotti] "Nowadays, do most broadcasters have their own broadcast safe filter applied to all their content due to go on air?"
Some might, some might not. Also they might either hard clip it or soft clip it, so it would be best that the footage is in order before you send it out. Some broadcasters might reject the file completely until it's fixed to the proper levels.
Jon Doughtie
on Dec 11, 2015 at 1:57:55 pm
It is often referred to as "sync buzz". The out-of-spec whites create distortions in the signal that bleed into the audio audio circuitry. Most commonly, this would be the IF coil. On old TV's where you had quick access to a brightness control knob, you could make it disappear by simply turning the brightness down, thus effective reducing signal strength in the circuit. On modern screens where you have to wander through menus, this is less practical as a solution.
Ultimately, broadcasters also pay attention to these signal specs because the FCC requires it.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Tero Ahlfors
on Dec 11, 2015 at 2:05:51 pm
My friend had a TV that would shut completely off if there was something really bright happening eg. an explosion. It was a bummer when we we're watching action movies.
Oscar Gotti
on Dec 11, 2015 at 2:41:46 pm
So do you still get sync-buzz on modern TVs? Or is just on old ones?
Andy Field
on Dec 11, 2015 at 7:57:03 pm
There's another reason -- standard levels across all stations......how much fun would it be to switch from one station to the next (or from one scene to the next in a show and then the commercial) with levels all over the place --
Andy Field
FieldVision Productions
N. Bethesda, Maryland 20852
