Video bitrate not matching target bitrate after compression
Ronnie Howard
on Dec 9, 2015 at 11:05:09 am
Hello you lot,
I'm trying to compress a video with a target bitrate of 15Mbps. However, the file that I end up with is only about 7Mbps.
I just did a test to see what would happen if I set it to 50Mbps and it only came out at 9Mbps!
I'm editing a HD project with raw MXFs in Premiere Pro that are 4K and have a bitrate of 252Mbps. I've scaled the 4K footage down to HD for a HD output.
And my compression settings (which have been given to me by our client for TV output) are:
h264 Mp4 AVC
1280x720
Main@ L4.1
CBR
Target bitrate: 15Mbps
I have another sequence in the project with rushes from the same shoot which is exporting out at 10Mbps, which is closer than the 7Mbps.
I'm sure there is a very logical reason as to why this is happening, but I can't figure out why.
Has anyone had a similar issue that they have resolved somehow?
Any advice is very much appreciated.
Vince Becquiot
Re: Video bitrate not matching target bitrate after compression
on Dec 9, 2015 at 6:09:40 pm
Hi Ronnie,
Make sure you uncheck any "match source" check boxes in the export window.
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
Ronnie Howard
on Dec 9, 2015 at 10:50:02 pm
Hi Vince
Thanks for responding.
I have unchecked the match source as I'm actually outputting at 1280x720.
I even tried exporting out a prores and then compressing from that but it's still coming out with a low bitrate.
Very confusing.
Ronnie Howard
on Dec 10, 2015 at 10:39:27 am
I figured it out.
I had a screen capture video that took up a lot of the timeline that was 692Kbps, so I was trying to force data that wasn't there.
Doh!
