Keying out green screen with a hotspot
Ashley Davis
on Dec 7, 2015 at 2:14:09 pm
So I shot a green screen interview the other day and managed to mess up rule number 1 and got a hot spot lighting the screen.
I had two cameras running - wide was fine but the close up has picked up a hot spot behind the actors face and I can't seem to eliminate a small area. (see pic)
http://tinypic.com/r/2zxtcm1/9
I'm using the ultra key effect in Premiere and setting it to aggressive. This usually gets rid of the majority of green but the spot above was over exposed, I have played with highlights/shadows, tolerance, pedestal etc but I can only seem to reduce the area slightly but not completely.
Any ideas? maybe something in AE?
Gabriel Coelho
Re: Keying out green screen with a hotspot
on Dec 7, 2015 at 3:52:41 pm
try to use the ultra key plugin
Ashley Davis
on Dec 7, 2015 at 4:01:11 pm
I'm using ultra key
Ivan Myles
on Dec 7, 2015 at 4:53:28 pm
It might be helpful to create and animate a garbage matte around the area, and then key out the hotspot colors.
Ashley Davis
on Dec 8, 2015 at 12:10:16 pm
Considered that but think its too close to the subjects face
Craig Howard
on Dec 8, 2015 at 1:45:09 am
Add a second UltraKey Effect to the clip and see if you can pick it up in that.
Craig Howard
Shooter Film Company
Auckland
New Zealand
Adobe CC2014 Suite, Resolve
Windows 7-64 bit:Assus P6T Deluxe Mob, 24 GB BM SDI Decklink, . HD Workflows
Ashley Davis
on Dec 8, 2015 at 12:17:47 pm
I did try this initially but had another go and has just about sorted it with the help of a bit of mask as well. Thanks, hopefully that'll do!
This has taught me a lesson about green screens!
