Markers disappear moments after reopening project
Oliver Wilkins
on Dec 4, 2015 at 12:25:20 pm
I have a frustrating problem where I have applied markers on an interview edit, however on reopening the project, I see the markers briefly in the sequence but, a split second later when the media is reconnected all markers disappear
Just to set the scene I am a novice at Premiere after years on FCP. I have imported 4K XAVC footage shot on the A7R2. I just let the new sequence go to default settings - having checked that now it says Editing Mode - Red Cinema.
I did notice that as I applied the markers, I got an error message "the file is busy..." However I just ignored it. Now it seems those markers have not been saved to the original clips for some reason...
1. Is there anything I can do to bring the Markers back (they do appear for the split second)
2. Should I be converting all this footage before importing to Premiere.
3. Should I set up customer settings on the sequence
Many thanks, Im kind of unsure whether I should quit and start again with converting everything to pro-rez. Buts it's going to be TBs of footage as I have over a TB of XAVC to start with.
Appreciate any pointers.
Oliver
