Head's Up regarding new CC update
Bob Pierce
on Dec 3, 2015 at 6:25:50 pm
The update that was released this week will update Premiere from 9.02 to 9.1. This new version will wipe out your old one. I don't believe it's possible to have both versions running on your machine (at least I haven't figured out how.)
This means every project you open that was made on 9.0 will now have to be re-saved to this new version.
Just a head's up.
Bob
_____________
Robert Pierce
Director of Photography • Editor
http://www.robertpiercemedia.com
Trent Happel
Re: Head's Up regarding new CC update
on Dec 3, 2015 at 10:50:55 pm
Correct. Excerpt from Premiere Pro blog:
Please note that the 2015.1 version of Premiere Pro will overwrite your 2015.0 installation. Also important to note is that 2015.1 requires a revision to the project format and as such projects saved in 2015.1 are not compatible with prior versions of Premiere Pro CC.
http://blogs.adobe.com/premierepro/
If you do need to go back to previous versions, here is more info from Kevin Monahan's blog:
http://blogs.adobe.com/kevinmonahan/2014/01/29/revert-to-a-previous-version...
Trent Happel
Adobe
Premiere Pro
