Adobe Premiere Pro CS6 export setting (film length varies once exported)
Pau Masó
on Nov 27, 2015 at 1:45:50 pm
Hello,
I was hoping someone can help me.
I recently exported a film from Premiere CS6. Here's the problem. The film is 1:25:37 in the timeline, but once I export it, it becomes 1:25:43 (6 second longer)
The reason that is a problem is that on Premiere I created subtitles based on the timing on the software, and when I use the .srt file with the exported version, the subtitles aren't in sync.
Another important thing to mention is that when I put the exported file on Premiere (the longer version), it becomes the short one on the software. So as an exported file it's longer and in the software shorter.
Is there an explanation to this?
Daniel Waldron
Re: Adobe Premiere Pro CS6 export setting (film length varies once exported)
on Nov 27, 2015 at 8:22:55 pm
Does the frame rate of your timeline match the frame rate of your exported video?
Ivan Myles
on Nov 28, 2015 at 6:16:43 am
What is the codec and export settings? What media player(s) did you use?
Tim Kolb
on Nov 28, 2015 at 10:31:48 pm
It sounds like a pretty fine error...what is the framerate of your timeline? 23.976? 24.0? Also check the framerate of the longer clip.
TimK,
Director, Consultant
Video Producer at I-CAR
