Feather using garbage matte
Oliver Smith
on Nov 26, 2015 at 4:47:41 pm
Is there anyway you can can add a feather on an eight point garbage matte? I've applied it but it only seems to feather the bottom half?
Any ideas? Or is this a job for AF?
Nathan McAlpine
Re: Feather using garbage matte
on Nov 27, 2015 at 12:52:54 pm
I rarely have good results with feathering in premiere. The feather applies to the whole image. You are probably cropping off the feather on the top and sides so you only see it on the bottom.
Nathan McAlpine
Commercial Producer
Ann Bens
on Nov 27, 2015 at 3:28:54 pm
You can do this in Pr.
Make white color matte, superimpose and drop the garbage matte on it.
Then add Fast Blur, set it to whatever value
Add track matte effect to clip, set it color matte
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Nathan McAlpine
on Nov 27, 2015 at 4:48:21 pm
Not sure why I never thought of that. Great solution!
Nathan McAlpine
Commercial Producer
Oliver Smith
on Nov 30, 2015 at 4:12:07 pm
Worked perfectly Thank you :)
