Need audio guru's advice on adobe premiere audio output
Spike Spiegel
on Nov 23, 2015 at 4:23:29 pm
Hi everyone! I'm trying to render out a 44 min project to a client's spec and need your advice.
The client wants channel 1: Full mix L Channel 2 Full mix R Channel 3: Mix minus (MDE only) L and 4: Mix minus (MDE only)R
What i've done is rendered out 2 24 bit wav stereo files; one is the full mix stereo, the other is MDE only stereo.
NOW, how do I tell premiere to give me 4 channels of audio with the configuration above? My tracks are prepared, the only issue i am having with now is at the exporting stage. Please advice. Much appreciated.
Andy Edwards
Re: Need audio guru's advice on adobe premiere audio output
on Nov 23, 2015 at 6:35:32 pm
Spike,
Have you used the search engine on this site or Youtube to answer your question? This type of question has been answered hundred of times and is available with a little work on your end.
Depending on what version of CC you are using, you need to set up your sequences as Multichannel and assign all your audio track correctly before making the multichannel export.
Take a look here:
or search Youtube for:
multichannel audio export in Premiere Pro
Andy Edwards
Spike Spiegel
on Nov 27, 2015 at 4:11:26 am
thanks that helped a lot!
