Master Exports
Oscar Gotti
Master Exports
on Nov 21, 2015 at 6:17:41 pm
Hello,
I am a Mac user, and I was just wondering what the best codec for exporting Master exports was? Apple Pro Res or H.264 (.mov)?
How easy is it for PC users to use Apple Pro Res, as opposed to H.264 (.mov)?
After every project, I usually export a Clean Master with split-tracks. Is it also wise to export my Dirty master as a split-track too?
Just wondering what your workflows are :)
Oscar
David Roth Weiss
Re: Master Exports
on Nov 21, 2015 at 7:12:28 pm
ProRes 422 is a vastly superior codec, and it's a hi-performance codec optimized for easy playback even at high bitrates. H.264 is a processor intensive codec, and better suited for acquisition and web delivery, because of it's high compression rates.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Oscar Gotti
Re: Master Exports
on Nov 21, 2015 at 7:17:52 pm
Thanks David,
But what is best for PC users? Pro Res or H.264 (.mov)? I am asking because we share a lot of our files via FTP for broadcasters to pick up should they choose to. And some might be PC based.
David Roth Weiss
Re: Master Exports
on Nov 21, 2015 at 7:33:32 pm
ProRes can be decoded (played back) on both Mac and Windows platforms equally well. Windows machines cannot encode to ProRes, but that has no bearing on mastering to ProRes, as it can be played and edited universally.
David Roth Weiss
Los Angeles
Ivan Myles
Re: Master Exports
on Nov 22, 2015 at 4:25:42 am
Consider DNxHD, AVC-Intra, or Cineform if encoding on a PC.
Andy Mees
Re: Master Exports
on Nov 23, 2015 at 7:16:07 am
Hey Oscar
[Oscar Gotti] "I am asking because we share a lot of our files via FTP for broadcasters to pick up should they choose to."
Broadcasters are somewhat unlikely to accept an H264 master... they tend to have strict guidelines as to what they will or will not accept. You'd be much much better off with a ProRes master. Should you need to deliver in a different format then you can transcode to that from your ProRes master.
[Oscar Gotti] "After every project, I usually export a Clean Master with split-tracks. Is it also wise to export my Dirty master as a split-track too?"
You might want to consider instead exporting your dirty master with a stereo full mix on ch 1 and 2, plus an international stereo full mix on ch 3 & 4.
Hope it helps
Andy
Oscar Gotti
Re: Master Exports
on Nov 24, 2015 at 1:14:49 am
Thanks Andy,
Is it okay to just have a stereo mix in cases where there is no VO or COMMS? I can't see the point in having channels 3 & 4 if they are going to be exactly the same as 1 & 2
Oscar
Andy Mees
Re: Master Exports
on Nov 24, 2015 at 2:25:41 am
[Oscar Gotti] "Is it okay to just have a stereo mix in cases where there is no VO or COMMS?"
Hey Oscar
Yes, absolutely. No point in keeping duplicate audio stems on your master.
Cheers
Andy
Oscar Gotti
Re: Master Exports
on Nov 24, 2015 at 7:23:02 pm
Thank you,
One more question:
From your experience is it more common for 4 channel stereo/M&E mixes to be in 4 mono channels? Or 2 stereo pairs?
Mayto
David Roth Weiss
Re: Master Exports
on Nov 24, 2015 at 1:48:12 am
Hey Andy!!! Long time no see my friend...
David
David Roth Weiss
Los Angeles
Andy Mees
Re: Master Exports
on Nov 24, 2015 at 2:22:55 am
I know! I should update my profile picture... far older and more haggard these days :)
Ben Marcheski
Re: Master Exports
on Nov 24, 2015 at 4:22:06 pm
You can never have enough clean masters! As a safety, perhaps export your audio as separate .wav files as well! You can always combine audio/video as new codecs are released.
Ben Marcheski
