PP - Redcine X roundtrip - multiple settings for one long clip?
Peter Lange
on Nov 21, 2015 at 4:01:54 pm
Hi Community,
its the first time for me to work with red files and i have a slight problem with the roundtrip to Redcine x and back to premiere.
my situation:
i am working on an edit inside Premiere with Red Epic files.
The Colorist wants to do his work in Redcine X and i want get the edit back to premiere after.
I thought about working with an XML export from premiere and then just relaod the RDM files.
Would work, but i have a lot of clips wich are minutes long and have different light situations inside, so there will be different grading on parts of the long clips.
So in this case RDMs are not working, because there is no way to save multiple RDMs, right?
Can anyone of you recommend a workflow for this?
i appreciate your time reading this!
Thanks you!
