Color out put differs from color in sequence.
James Barry
on Nov 6, 2015 at 3:31:51 pm
So I'm running into an issue where my export's color is very very different from the color I see in my PP sequence.
I'm using the Vimeo 1080 preset to export from a UHD sequence, not sure if that info is helpful.
Specifically it looks like my footage is over exposed in my export, by like a full stop. I have not tried to stop down my sequence yet, I thought I would preemptively ask here first.
Thanks.
Jon Doughtie
Re: Color out put differs from color in sequence.
on Nov 6, 2015 at 5:05:30 pm
What screen(s) are you using to view your timeline and your export? If on the same monitor, what application are you using to view the export?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
James Barry
on Nov 6, 2015 at 5:44:39 pm
Both timeline and export were viewed on a 27" iMac with retina 5k. I viewed the export in Quicktime and VLC.
James Barry
on Nov 6, 2015 at 5:51:43 pm
Steve Brame
on Nov 6, 2015 at 5:46:02 pm
Interesting. I've just discovered the same problem. I've got Ultra-keyed footage against a still background photo, with a Lumetri effect on the foreground. On export to H.264 and Avid MXF, it looks as if the Lumetri grade is being ignored. I also tried Matrox AVI, and that works much better. The difference in the exported image and that of it in the Program monitor is stark.
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive - WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) - WD Velociraptor 10K drive 600GB * Media Drive - 2TB RAID0 (4 - WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
"98% of all computer issues can be solved by simply pressing 'F1'."
Steve Brame
creative illusions Productions
James Barry
on Nov 6, 2015 at 5:50:08 pm
Yeah it's very odd. You can see how different the export is from the timeline
