5D MKiii 50Fps footage playing back at 200%
Adam McCormick
on Nov 6, 2015 at 1:14:03 am
Hi All,
Exactly as it says, the footage is shot in 720p at 50fps. When playing back in premiere it plays as though at 200% speed. Once interpreted to 25 it plays back at normal speed instead of Slo MO. I have tried multiple sequences including using the actual clip to create a sequence, all with the same result. The other thing is that if I play the clip back in the finder it does the same thing, which suggests it might be more related to a computer or possibly quicktime issue. I have also tested this on a different mac pro and it works correctly.
Config is MacPro4,1 Premiere CC2015 10.9.5 AMD Radeon HD 7970 3072 MB graphics
