Transcoding XAVC footage to Pro Res
Magee McIlvaine
on Nov 5, 2015 at 6:09:19 pm
Creative Cow Community,
I am looking for some quick transcoding help and advice. I have some XAVC footage that I need to transcode quickly to Pro Res for a client. I know Catalyst Browse can do it, but I'm hesitant to fork over $200 (my trial version expired). Could this process be as simple as bringing the XAVC raw footage into a Premiere CC timeline and exporting out from there to Pro Res? What risks (ie quality loss), if any, would there be in just doing that?
Looking forward to hearing your thoughts.
-Magee
David Roth Weiss
Re: Transcoding XAVC footage to Pro Res
on Nov 5, 2015 at 6:19:55 pm
And the reason you're not using Adobe Media Encoder is???
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Magee McIlvaine
on Nov 5, 2015 at 6:38:57 pm
No. Good point. Any difference between using Adobe Media Encoder and Sony Catalyst Browse?
Thank you for the quick response!
David Roth Weiss
on Nov 19, 2015 at 12:12:15 am
Resolve is a good solution... However, though you can't see it necessarily, ProRes LT is NOT the best choice when transcoding from XAVC - you will lose some information, especially when you go down generations in later encodes, etc. ProRes 422 is best for HD, and ProRes HQ is best for 2K and above.
David Roth Weiss
Los Angeles
Jon Schwartz
on Nov 18, 2015 at 10:17:50 pm
Its that easy. I am on a gig now using Davinci Resolve 12 to make ProRes. I think thats the ticket. There is no loss of quality specifically in that way of transcoding the footage, just whatever you would normally lose depending on the type of prores used. Im seeing a decent image here going to proresLT. check the bitrates of prores codecs compared to xavc.
Jon
