File/Sequence List
Eric Santiago
File/Sequence List
on Nov 4, 2015 at 12:45:34 pm
Is there any utilities that will export a sequence clip list or something that would tell me where a clip is being used as well as timecode?
Working with a lot of files shot with a DSLR and its not as easy as my RED workflow.
Jon Frost
Re: File/Sequence List
on Nov 4, 2015 at 11:53:26 pm
You could export an EDL - Edit Decision List.
Jon Frost
Easthampton MA
Eric Santiago
on Nov 5, 2015 at 1:59:10 am
Exported both EDL and XML but its a mess to deal with.
If I had some XML coding knowledge Im sure I can sift through it but was hoping for an Utility of some sort.
Eric Santiago
on Nov 5, 2015 at 2:26:52 am
Found on helpful option in Project window.
Turned on Video Usage and it allows me to see the clips sequence use.
Thats helpful but again a nice text file would be best.
Stephen Abbott
on Nov 5, 2015 at 3:14:24 pm
Hi Eric,
I recently pushed out a lot of subclips into a spreadsheet. I'm also not really XML-literate, so I imported Premiere's XML export into FCP7, then used the batch list export options to get a simpler text list. A bit of text bashing and it was spreadsheeted neatly. I realise this will be useless if you don't have FCP7/Mac. In that case, send me a trimmed project as an XML export and I'll sent it back in text.
(Edit: I'm in South Africa / GMT+2, so depending on where you are this might take a little time to round-trip.)
Stephen Abbott
Eric Santiago
on Nov 6, 2015 at 12:10:12 pm
Hey thanks for the offer Stephen and great tip :)
I have FCP 7 on an SSD put away so Im good at that point.
Again thanks :)
Stephen Abbott
on Nov 6, 2015 at 12:32:21 pm
A pleasure! FCP is very civilised in what it exports: you can hide and re-order the metadata columns for a neat custom export for less text-bashing down the line...
Stephen Abbott
Eric Santiago
on Nov 6, 2015 at 1:47:31 pm
I work mostly in RED and love the export options from REDCINE-X.
