Audio Filters Missing From Exported Media File!
Harrison Gruber
on Nov 3, 2015 at 6:28:11 pm
Hey All,
So I went to export my project, rendered everything. Then when I watched my output file I noticed none of the audio filters I had used (namely the DeNoiser) were there. It was the original terrible unfiltered audio.
I tried exporting JUST the audio as an AAC to see if the problem was still there when I wasn't dealing with h264 compression codecs or something and even the AAC file had the problem---no filters. Wierdly I HAD put an audio gain on the original and THAT was preserved. But no DeNoiser.
Any thoughts?
Metadata here for my media: (Audio was recorded by onboard mic at 48kHZ)
Type: MXF
File Size: 466.12 MB
Image Size: 1920 x 1080
Frame Rate: 23.976
Source Audio Format: 48000 Hz - 16 bit - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00:01:15:12
Pixel Aspect Ratio: 1.0
MXF File details:
Wrapper type: MXF OP1a (type: SingleItem SinglePackage MultiTrack Stream Internal)
File generated by: CANON, EOS C500 (1.00)
MPEG-2 422 Long-GOP
Nathan McAlpine
Re: Audio Filters Missing From Exported Media File!
on Nov 4, 2015 at 4:38:46 pm
I've had this same problem. I was doing a 'quick' audio fix to a student film with a small budget and I worked through 90 minutes of audio in Premiere. I couldn't get any of the filters to export. I had to redo the whole thing in Audition. That was a year ago so I was hoping an update had fixed this by now but I only use Audition to add audio filters now.
Nathan McAlpine
Commercial Producer
Harrison Gruber
on Nov 4, 2015 at 10:56:04 pm
Still not fixed. Boo, Adobe. This has been an issue for over 4 years now.
