export sequence mac/pc
Reggina Falange
on Nov 2, 2015 at 1:03:11 pm
Hello all!
First of all i would like to thank you for answering so many of my questions all this time!
My problem is this :
I have 2 computers, one mac mini and one pc. I am currently working premiere pro cs6 on the pc. When i want to export a sequence on the pc and i check the box "match sequence settings" my file is exported as .mpeg
This doesn't happen on the mac. Using the same sequence and same settings, when i check the "match sequence settings" box, i get a file extension .mxf
I also created a test sequence on my mac (the export option here is the .mxf file), and then opened the exact same sequence on the pc. (i copied all the files there as well). When i went to export it, the option .mpeg was there.
Why is that? I need the .mpeg option, which i cannot find anywhere. Is there something i must to in order to get that? I really need to start working on the mac, but this issue doesnt make my work any easier.
Thank you all in advance!
