magnifying on still image premiere pro
sam dias
on Oct 29, 2015 at 7:24:20 pm
OK I need help with something which will be for most of you very simple. I'm working on a documentary and this is what I want to achieve. I want to show a still image ( a letter) I then want some parts of the latter to come forward which I lay a voice reading it.
I don't know what this this effect is called so if you understand what i am trying to achieve, please help.
Jon Doughtie
Re: magnifying on still image premiere pro
on Oct 30, 2015 at 3:56:36 pm
Hi Sam. I want to be sure I comprehending the finished look you are seeking.
If I am understanding you right, you want part of the letter image to "lift above" the rest of the letter as you read that part. This is different from simply zooming in to a portion of the letter.
Have I envisioned your goal correctly?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
sam dias
on Oct 30, 2015 at 5:12:34 pm
Hi Jon,
thanks for your reply,
if you have the time watch thsi video,
this is more or less what i want to do.
Many Thansk
Shane Ross
on Oct 30, 2015 at 5:39:59 pm
So the zoooming out of DEEZ NUTS and DEEZ W NUTS, where the background goes darker? This is best done in Photoshop and After Effects. Put the document on the lowest level...and you can scale it to fill the page...and then keyframe the movement top to bottom. Stop it where you want...etc.
Now, in Photoshop...using that main document, select the areas you want to move out to the front. And COPY and PASTE them onto new PS documents...making separate files. Now, layer those into AFTER EFFECTS as well, so when you stop, you put these on the layers above...scale them down and adjust them to start where they start on the document...then scale them up and bring them to where you want...keyframing the movement. And then at the same time, keyframe the opacity of the main document down to 30% or so. Defocus it too, if you want to make those really stand out.
Shane
Little Frog Post
