Transcoding Presets in Prelude
David C Jones
on Oct 26, 2015 at 3:08:20 am
I'm looking at transcoding our all our footage to ProRes422HQ and would love advice on using the correct settings in Prelude. I didn't see ProRes as a preset but it is and I'm just unclear on which it is. Any help would be most appreciated.
DCJ
Kevin Monahan
Re: Transcoding Presets in Prelude
on Oct 27, 2015 at 9:36:16 pm
You can create your own ProRes presets via the QuickTime option in Transcode. You can also import them from your AME Documents folder.
Kevin
Kevin Monahan
Support Product Manager—DVA
Adobe After Effects
Adobe Premiere Pro
Adobe
Follow Me on Twitter!
David C Jones
on Oct 28, 2015 at 3:41:56 am
Thanks Kevin!
At this point, I've decided to stick with using the native format.
But I'm still not finding how to create my own presets via the Quicktime option in Transcode. If I'm in Prelude, select Ingest, Transfer, Transcode and then select Quicktime as the format, what should be the correct Preset be? I've done an extensive search for a tutorial that would help, but I haven't found it.
DCJ
