Forgot where Premiere Pro stores temp files
Duke Sweden
on Oct 22, 2015 at 10:48:31 pm
There was a post a while back that mentions a file folder where Premiere Pro stores temp files. It's NOT the one in preferences that comes with a "Clean" button, you have to go to the folder in Windows Explorer and delete the files manually. I can't remember the path to that folder. Does it ring a
bell with anybody?
Ann Bens
Re: Forgot where Premiere Pro stores temp files
on Oct 22, 2015 at 11:52:50 pm
users / name / appdata / roaming / Adobe / common
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Duke Sweden
on Oct 23, 2015 at 1:23:18 am
Thanks but that's where the media cache files are, that can be emptied using the "Clean" button. There is another folder where temp files and copies of project files are sent, that you have to delete manually. It's in another thread here somewhere but I can't seem to find the right search term to find the post.
Ann Bens
on Oct 23, 2015 at 12:17:27 pm
You need to clean these manually if the path in the pref is different.
Jon Doughtie
on Oct 23, 2015 at 4:30:38 pm
Look in users / name / appdata / local / Adobe / temp
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Duke Sweden
on Oct 23, 2015 at 5:02:37 pm
Thanks. There's no temp folder there.
Jon Doughtie
on Oct 23, 2015 at 7:01:33 pm
Error on my part - sorry!
Try \Users\name\AppData\Local\Temp
System:
Win 7 64-bit
32GB RAM
Duke Sweden
on Oct 23, 2015 at 10:56:52 pm
Thanks again. That's not the folder either, judging by the current contents. I checked my comment history here but it gets cut off before the comment where I originally mentioned having seen this.
