Premiere Pro Crash - How to begin debugging
christina rule
on Oct 20, 2015 at 8:38:31 pm
I am reaching out to my fellow Premiere people in hopes to save my sanity.
Premiere crashes on me on a daily and I'm trying to figure out what exactly is causing the issue. I've tried re-installing, updating, cleaning off drives, clearing unused footage from projects, removing FXs and nothing seems to help. I am curious as to where I would start to actually try and find what is causing the program to crash. Is there a log I can go through?
I'm using PP CC 2015 2015.0.2. release
windows 7 professional
intel r Xeon (r)
96GB memory
64bit
thanks in advance
http://www.christinarule.com
jerry wise
Re: Premiere Pro Crash - How to begin debugging
on Oct 20, 2015 at 11:06:08 pm
you might try trashing your preferences.
Eli Coogan
on Oct 21, 2015 at 6:18:29 pm
I'm in the same boat, but as far as possible solutions, I've encountered:
- Uncheck "Sum multichannel outputs to Mono in Source Monitor" and "Maintain pitch while shuttling" to solve the source monitor scrubbing crash.
- Yesterday, on my post, Kevin responded about using OpenCL instead of CUDA if you have it, and trying to check your permissions folders. Also, basically not having any other program open. The thread here:
https://forums.creativecow.net/thread/3/970837
- I've heard that if you're starting a project on another computer and switching it over, instead of just opening it, you should start a new project and import it.
Other than those, I'm still searching for a way to make it more stable. I've been crashing three or four times a day. Pretty frustrating.
