Premiere Pro to DaVinci Resolve Workflow Issue
James Bacskay
on Oct 20, 2015 at 2:14:16 am
Potentially a stupid question, but does anyone know how to export a timeline from Premiere Pro to DaVinci Resolve, whilst retaining any third party effects already added in Premiere Pro? My main issue is that I have a copy of Neat Video for Premiere, but only have DaVinci Resolve Lite, which of course does not have a noise reduction feature. So, I need to find a way to get my de-noised timeline into DaVinci Resolve. Any help or advice is greatly appreciated.
Alex Udell
Re: Premiere Pro to DaVinci Resolve Workflow Issue
on Oct 20, 2015 at 5:32:32 pm
Hi...
Something like this:
1) You will need to duplicate your sequence in PPro that has the effects applied
2) in that duplicate sequence you will need to select all video, right click and do "render and replace" this will make new clips in the codec of your choice with the effects backed in and the amount of edit handles you specify
3) once that is done....you can export that sequnce as a FCP XML and that should carry to DaVinci for grading...
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
James Bacskay
on Oct 22, 2015 at 12:34:18 am
Awesome!
This is just what I was after. Thanks Alex! :)
Jo Liesendahl
on Oct 22, 2015 at 4:21:55 am
Hello Alex,
are you sure, that "render and replace" generates a new clip with sfx on?
On my system I just get new clips in a new codec but without rendered effects.
Best, Jo
James Bacskay
on Oct 22, 2015 at 5:36:54 am
Hmmm...
You're right, Jo. I've taken to exporting a complete sequence and then using the cut detection function in DaVinci. It's not the greatest workflow, but it achieves the desired result.
Alex Udell
on Oct 22, 2015 at 2:23:37 pm
Hmmmm...you may be right...I was just thinking about this...
might require individual clip nests....
then render and replace...
Alex Udell
Alex Udell
on Oct 22, 2015 at 4:07:36 pm
Nope...even that doesn't work.
comps can't be rendered and replaced with a clip...
grr
Alex Udell
Eric Santiago
on Oct 22, 2015 at 6:08:00 pm
Basic transforms work.
None of the effects transfer.
Nick Ferreiro
on Jan 27, 2016 at 11:17:06 pm
Hi I have the same question.
If I am just hoping to use DaVinci for CC on my sequence. Think I will try this:
1) Apply the NeatVideo effect in PP
2) Export that timeline to something like an Apple ProRes
3) Bring that video file into DaVinci and just use Scene Detect
Might not be the fastest, but I think I will accomplish everything I am aiming for (NeatVideo with PP, Coloring through DaVinci). How does that sound?
