the need for speed
Steve Ford
the need for speed
on Oct 19, 2015 at 7:54:06 pm
I have a graphics card question. I'm currently running a mac pro (mid 2010) with 2 x 2.66 GHz 6-core intel Xeon processor. 24 GB 1333 MHz DDR3 ECC Ram. A NVIDIA Quadro 4000 2048 MB graphics card. Here is my question, is there a faster graphics card out there for mac? I'm having issues with smooth play back in HD in Premiere and of course I would love faster renders in Premiere as well as AE. Normally I have both Premiere and AE open at the same time, do you think 24 GB of ram is enough?
Alex Udell
Re: the need for speed
on Oct 19, 2015 at 8:19:57 pm
In your prefs for PPro...
how is your Ram Allocated for Adobe apps?
How much is left for the OS?
what kind of HD?
what kind of drive is it playing off of?
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Steve Ford
on Oct 19, 2015 at 8:39:19 pm
I have 12 gigs allocated to PPro. HOw do I figure out how much is left of the OS? I us the Apple ProRes 422 HQ. My storage is a G-Speed eS PRO, 8 TB ENTPRS
Alex Udell
on Oct 20, 2015 at 1:56:15 am
Hi Steve...
sounds like a pretty good configuration.
The Nvidia card should be quite good.
I'll let another expert chime in on the RAM but more certainly can't hurt.
Some workflow questions:
1) is 422HQ absolutely necessary? maybe it's a data rate issue with the amount of streams you are calling
2) what do you have your playback resolution set to in your program window?
3) What's your Preview Set up to in the Sequence. If you set it to match your working Prores codec, those preview files generated for any renders you may do during working can be used during export (if you enable use previews), which can speed exports significantly.
hth,
Alex Udell
Walter Soyka
on Oct 20, 2015 at 9:50:13 am
The Quadro 4000 is actually a bit underpowered: it sports only 256 CUDA cores.
Do you notice a big difference in performance between Mercury's software-only mode and hardware-accelerated mode?
Walter Soyka
