Basic audio sync workflow question for Premiere
Dale Holman Wallace
on Oct 19, 2015 at 4:26:32 pm
Hi there,
I'm looking for the simplest, most efficient workflow for syncing audio to proxy files in Premiere Pro, with regards then being able to easily re link to then raw files.
If I merge the rushes and audio, I am concerned the file name that is created will be different to the raw file, therefore making relinking problematic. However, it would be useful to link the files so that I can dump them in a bin and go through and find the files I need like that, rather than simply have a timeline of footage with audio synced in the timeline alone, if that makes sense.
Dale
Andrew Kimery
Re: Basic audio sync workflow question for Premiere
on Oct 19, 2015 at 7:05:04 pm
You can create a single camera multicam clip (which is basically just a nested sequence).
