After Effects laggy in Premiere Pro when rendered
Daniel Stankler
on Oct 15, 2015 at 10:04:01 am
Hi all,
So I've made an animation in After Effects which I've then imported into Premiere Pro, and no matter what settings I render the finished product into, the graphics on the resulting video is extremely laggy/choppy/slow. I've tried exporting it in loads of different settings, I've tried importing it into Premiere Pro as an After Effects file, or as a rendered video of various settings - nothing changes this lagginess.
Does anyone have any ideas?
Thank you!
Alex Udell
Re: After Effects laggy in Premiere Pro when rendered
on Oct 15, 2015 at 10:41:33 am
Hi Daniel....
need some clarity....
Are your clips:
1) some sort of movie with an alpha channel for layering over other vids
2) Just vids?
3) Dynamically link AE comps?
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Daniel Stankler
on Oct 15, 2015 at 11:02:26 am
They're a combination of the latter two - I'm combining mp4 footage with a dynamically linked AE composition. But I've also tried rendering out the AE composition in After Effects to mp4, importing that file into Premiere Pro instead of the AE composition, and neither makes a difference to the laggy appearance of the finished rendered Premiere Pro movie.
Hope that helps..
Alex Udell
on Oct 15, 2015 at 11:18:34 am
What resolution?
Is ProRes an option to render to or are you on Windows?
Alex Udell
Daniel Stankler
on Oct 15, 2015 at 11:25:25 am
Resolution is HDTV 1080 24, and I'm on a mac but not using ProRes since I don't have Final Cut or Motion.
Alex Udell
on Oct 15, 2015 at 11:59:21 am
Hmmm....
issues tend to center around whether the compression is making the computer work hard or the data rate of the encode is too high for the disk it's playing back from.
mp4 so is sooo configurable, it could be either of those two things....
what are the properties of the video you are combining it with?
does that play ok?
what kind of drive is it playing off of?
Alex Udell
Daniel Stankler
on Oct 15, 2015 at 1:09:47 pm
The computer is a 2015 Macbook Pro 13" with 2.7GHz Intel Core i5, so not outrageous but definitely good enough...
The video I'm combining it with 1064 by 768, fairly low quality. It's impossible to say whether it does or doesn't play well because of the nature of the video - it's a recording to a static powerpoint presentation, so nothing really needs to 'move' smoothly. The frame rate on this video is something like 4. I can't imagine this video is the problem.
Also when I export the animation straight from After Effects, the resulting video plays completely smoothly. It's only when I try and put it into Premiere Pro and export it from there that I have a problem...
Alex Udell
on Oct 15, 2015 at 1:28:55 pm
What are your sequence setting in Premiere, including frame rate?
thanks...
Alex Udell
Daniel Stankler
on Oct 15, 2015 at 1:53:23 pm
...The frame rate was set to 10. Now I feel silly.
Thank you!
Alex Udell
on Oct 15, 2015 at 2:18:22 pm
no worries my friend! Glad we got it sorted!
Alex Udell
