Nested Effects can't be extended.
Eric Merklein
on Oct 14, 2015 at 4:59:24 pm
If I nest a two layer effect, I can't add a dissolve in my time line or a transition effect. The nested is EXACTLY the same length as the originals PERIOD.
Is there a setting that I'm missing or is this just a bad mistake by Premiere Pro?
Eric
Many thanks.
Alex Udell
Re: Nested Effects can't be extended.
on Oct 14, 2015 at 5:11:51 pm
Hi...
so you have trimmed a set of clips....
created a 2 layer effect...
nested it...
then in the parent sequence want to trim it out or add a transition?
Probably have to add some handles in the nest...PPro's not going to assume you want anymore media exposed then you exposed at the time you made the nest...
am I understanding correctly?
am I misunderstanding your intent?
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Eric Merklein
on Oct 14, 2015 at 5:16:26 pm
Hello Alex.
You understood my plight correctly. I'm used to Avid where I can nest 6 video layers, then add a dissolve or transition effect. The extra footage is computed for me.
I guess your right about adding trims at atop and tail as the only fix.
Thanks for getting back to me.
Eric
Many thanks.
Alex Udell
on Oct 14, 2015 at 5:38:01 pm
Well it depends on how you construct your sequence, right?
If you stack your nest over the clip you want to transition to...
then you can add the effect at the tail and it will work...
if you want to do the transition within the same track and you didn't account for handles when you made the nest...
open the nest and add some handles to the source....
then you can dissolve in the parent in the same track...
either way, PPro doesn't handle the detection automagically...
Alex Udell
Eric Merklein
on Oct 14, 2015 at 7:00:24 pm
Great advice. many thanks.
E
Many thanks.
