H.264 Codec from PC not working on Mac
Scott Clark
on Oct 13, 2015 at 4:52:50 pm
So I just made the switch over to working on a PC with Adobe Premiere, and am having trouble with the H.264 codec. When I export from the PC, and play it back, it works fine. But when I try to play the same file on a Mac, it skips and stutters. I usually do a custom setting to have a higher target bit rate, but other than that, all the settings match the sequence. When I export as a mov. codec, it works fine on both. Any thoughts on why this keeps on happening? Thanks in advance!
