Composite Video Capture Card with Audio
Durwood Hibbard
on Oct 12, 2015 at 12:51:20 am
Greetings,
I am trying to help out a local church with an issue. They had their video recording computer stolen and have since replaced it. However, they are in need of a capture card for there computer.
They are dealing with SD video and need a composite input with standard (not optical) audio input.
It has been a while since I Have been shopping for anything like this and would like some input as to what would be a good PCI capture card that could be used that is compatible with PP CS6?
Thank you
Yes, Yes I do realize I have no clue what I am saying.
Chris Wright
Re: Composite Video Capture Card with Audio
on Oct 12, 2015 at 2:23:05 am
Adobe supports I/O cards from AJA, Blackmagic, Bluefish and Matrox and should be
compatible with any OCHI-compliant capture cards.
Shane Ross
on Oct 12, 2015 at 6:13:31 am
The current line of AJA cards don't have component nor composite inputs. Only SDI. Best to look at Decklink options.
Shane
Little Frog Post
Durwood Hibbard
on Oct 13, 2015 at 7:00:37 pm
Thank you for the quick responses, Much appreciated. I will look into those options.
Kannan Raghavan
on Oct 12, 2015 at 7:13:23 am
https://www.blackmagicdesign.com/products/ultrastudiousb3 or https://www.blackmagicdesign.com/products/intensity
Kannan Raghavan
The Big Toad Films Pte. Ltd.
Ann Bens
on Oct 12, 2015 at 10:18:26 am
Get yourself a grass valley converter and firewire card.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
