What is the most efficient way to reduce audio range on a clip and/or track in Premiere Pro CC?
Yair Bartal
on Oct 7, 2015 at 2:56:48 pm
As the subject says.
The highest audio is too high whereas the lowest audio is too low.
Jon Doughtie
Re: What is the most efficient way to reduce audio range on a clip and/or track in Premiere Pro CC?
on Oct 7, 2015 at 3:50:54 pm
The first thing I would try is dropping the "Dynamics" audio effect on it, and seeing if I can get a setting that adjusts things how I like them. Some compression and limiting may get the job done if you don't have too much background noise.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Alex Udell
on Oct 7, 2015 at 4:02:45 pm
to add to what Jon said...
if you can move all the items from that source on their own track...
this can be applied at the track level in the mixer (as opposed to clip the clip level)
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Yair Bartal
on Oct 7, 2015 at 6:33:27 pm
Thanks Alex.
Do you mean using the track mixer's volume control manually while playing to record "better" volume levels on the fly?
Alex Udell
on Oct 7, 2015 at 7:09:23 pm
No I'm saying that the effect Jon speaks of can be applied in the audio mixer at the track level...
as opposed to applying it to clips...
so if u have material as a group that needs this treatment...
putting them all on the same track might be helpful....
Alex Udell
Yair Bartal
on Oct 7, 2015 at 7:38:14 pm
Thanks Jon and Alex.
I'll give it a try.
